99600triple
I have a 99 Vmax 600 triple and I have just recently had issues with the electrics. The headlight, taillight, speedo, tach and all thing electric except the ignition have been flickery and would sometime even shut down completely.
Any thoughts??
Any thoughts??
super1c
Super Moderator
Sounds like a wire harness rub through. Time to pull harness out from under motor and inspect. Very common, do a search been covered a lot.
99600triple
Do I have to pull the motor in order to inspect the harness?
Vincent
What most do is disconnect all connectors on one side of the harness, tie a rope to the end and pull the harness out, inspected, repair it, and pull the harness back threw with the rope. Some even reroute the harness around the engine after. No need to pull the engine.
99600triple
Ok so just an update. Upon closer inspection the culprit turned out to be some meddling mice chewing through my wires. I’ll be sure the shove some bounce sheets in there! Thanks everyone for your suggestions!
