Mortagleus
Had sled running for about 40 min in an hours time. Started good. Warmed up for about 10 min, Went and filled up gas. Drove to a buddies about 15 min shut it down. Then started idled for a bit then we headed out about 15 min later at about 70km/hr lost power but still running pulled over and shut it down. Tried to pull over but had seized clutch side cylinder. Sounds like somethings grabbing when trying to turn primary by hand. Spark plug was grey, other 2 were perfect brown. Top of cylinder throught the plug hole looks smooth flat grey didnt see any pitting Was should i look at as a cause, compression was about 120 across the board all 3 before.
