shofreak43
I'm in need of help on my 97 sx 700. I replace the stator last year because the sled had no spark. This year I noticed the spark seems weak I cant get the sled to run at high rpm at 7k it seems to brake up really bad. also after a 30 mile trip if I shut the sled off and try to fire it up its very hard to start and I cant see any spark . any input would help . Any wiring diagrams , a way to ohm out the new stator or the plug wires coils anything . I'm at a loss and don't know were to start.
Vincent
Try changing you plug caps. Maybe fresh plugs while your at it. Also is your stator a Yamaha or an aftermarket? Aftermarkets stator have a reputation for being hit or miss
shofreak43
I can try changing the plug caps plugs are brand new, its a aftermarket stator,
if you have the old caps still on ....change them they have a way of going bad
s10mike
if caps dont fix the problem, i would check that stator with an ohm meter. those non oem units are known problems
shofreak43
What wires do I check to ohm test it ?? I kind of need a wiring diagram do you have one?
8vo fan
I had a nearly identical problem with my 700. After buying a new oem stator, I found out it was the plug caps all along! Mine would start and run fine cold. Nearly impossible to start hot.
A couple of bucks
Just change them out. If they are factory, they are WELL past their prime.What wires do I check to ohm test it ?? I kind of need a wiring diagram do you have one?
https://totallyamaha.net/showthread.php/75436-Change-your-sparkplug-caps?highlight=TB05EMA
Plug caps in post #30
https://totallyamaha.net/showthread.php/93790-Iridium-spark-plugs-in-a-redhead?highlight=Denso
