Exciter jugs
Bach420
Canada
Hi , I currently have a 93 sx. Question is can I use jugs from different models ? Same year? Like the ex model? They are way easier to find and alot cheaper to acquire.
Any of the other year 570 cylinders will work, but the SX porting is different then any year Exciter. So yes you can but I would stick with the later years that are Nikisil lined, and either just bolt them on or grind the ports to match the SX's. Obviously if you just bolt them on performance will be affected.
More than just porting is different on the SX. Intake runners on cylinders are shorter. Will be tough to fit the carbs. Head and gasket are also different. Can be done but more to it than it looks on the surface.
opsled
