Hi
Have some problem with the primary clutch on my Yamaha ET340. After a cold start it will run good for a few kilometers of deep snow driving then it starts to jam and the engine "dies" on idling speed.
Did someone have an idea what can possibly be wrong?
Skickat från min K10000 Pro via Tapatalk
i would start by blowing out the clutchs to remove the belt dust from over the years. if it still does it then, you need to replace all the bushings in the clutch. yamaha used to make a kit to do this listed in the parts breakdown under axuiliary clutch if i remeber right.
How complicated is it to rebuild the clutch if a rebuild is needed?
Easy with the right tools and some strength
Vincent
Well-known member
Are those pins actually correct parts?
