Power Valve Repair DIY?
RXMax
Central MN
I found all the posts about repairing a pull through, but does anyone have the instructions for repairing one with the shoulder bolt? length of bolt and type?
Thanks!
That fix is NOT a permanent fix. After miles of use the bolt will loosen no matter what you do. The best fix is the 3/16 brake line fix. Do a search you will find it
