Question on viper pipe
RB2001SRX700
Lifetime Member
Ballston Spa
I'm losing the heat shield on my 02 viper. Will this affect the sled or cause any damage? Thanks for the help.
Give me your address, I can send you a couple replacement straps if you want. Otherwise just heat tape the belly pan around your pipe.
Sorry for the delay getting back to you. Thanks for the info. If I take the shield off will it heat the hood up as well? Or would I be fine? And would I lose to much heat from the pipe for it to. Run right?
