crevon2431
Just finished rebuilding the top end over the weekend, changed all the gaskets and sealed the crankcase halves. The engine started right up and one of the plugs started dying, found antifreeze around the igniter. anyone had this problem? would the pump mechanical seal leak cause this to happen?
super1c
Super Moderator
Sounds like a bad head or base gasket.
