NorthernSX
Both 700 redheads, far motor has Wisecos, near motor say "ART" on the inside of the piston.
Near motor is ported, far is not.
Why is the bottom cut out of the skirt on the far one ?
Does that not affect timing ??
I believe thats to allow for air and fuel to get into the case quicker at the transfer port is slightly blocked.
NorthernSX
Ok, well, am I OK using the notched wisecos in the ported motor ?
Do the wisecos come like that ? Or has someone notched them?
I have seen guys notch them.. not sure if they came that way or not.
NorthernSX
I know my 600 twin comes with notches stock.
Mine is ported and those notches get bigger with porting.
But, thats not a case reed engine. Not sure if that makes a difference or not.
NorthernSX
Anyone else have insight on this? Need to decide which pistons to use.
mrviper700
VIP Lifetime Member
someone made the lower skirt notchs to advance rear boost port timing, it wont hurt to use those in another engine. If it were me I would add a "boost hole" to the stock Yamaha "art" pistons as they are the oem Yamaha pistons and do not have the warm up 4 corner heat expansion problems the wisecos due. Wisecos are ok as long as you have the right cylinder to skirt clearance...and let the engine warm up well before riding it everytime. they run a lot more skirt clearance to make up for the expansion rate, usually you need .0035-.0038 with them.
NorthernSX
By boost hole, do you mean the notch like the Wiseco has?
sxviper-s
I am not familiar with the boost hole either. I take it the hole increase the intake charge? How large of a hole is this? How far up from the bottom of skirt should it be placed? Would you happen to have a picture? Thank you.
