Hi, what is the tallest lug height that can be put in a viper without changing drivers, heat exchanger protectors are removed. Thanks
Vincent
Many have run 1.5" without issues
with the tunnel protectors out and front heat exchanger guards removed a 1.75 lug will fit with 9 tooth drivers. I ran this for awhile but ended up trimming the lug to 1.5 as it kept the tunnel cleared out much better and added some topend speed back.
