Crank seal replacement
monte44
MN
What kind of job to split crank case on 78 et250? I've done seals on other sleds but not an et with the vertical case. Do I need any special tools? Any help/tips would be great. Thanks.
had a look at a parts catalog .... same pain as most ... removal of clutch and flywheel .... screws appear to behind flywheel .... after they come out , tap with mallet around the case halves
until they separate ... don't jam a wedge in between casings as it is a polished fit with a fine film of sealant and screwdriver gouges are a bad thing... two of the holes have dowel pins
as well to keep things square ...
http://www.boats.net/parts/search/Yamaha/Snowmobile/1978/ET250B/CRANKCASE - CYLINDER/parts.html
I like this site
Ron
