vmax 500 dx clutching
ontguns
sioux-lookout ont.
Hi everyone I'm looking for help on my 1995 v-max 500 DX. When I bought sled 3yrs ago it had a over rev. problem from the get go, I checked the primary and found a worn weight and one bushing in a roller that had worn out. I ordered a new set of weights and rollers as well as rivets all OEM stock parts. I also rebuilt the engine as well but I canot get a ride due to over revving from stopped all the way to WOT. what I need to know is what is the twist rate of the secondary stock. and what the heck is going on and how can I fix this.. please help I'm not a clutch person...
95 500 dx, 70 degree twist. Check in the tech section for stock specs. You'll probably need a heavier rivet in tip of weight to bring down rpm's
