NHTodd
Alrighty guys and gals it's track buying time and I don't have a clue as what to look for. Any help would be appreciated.
Thanks Todd
Thanks Todd
super1c
Super Moderator
A nice 1” lug would be perfect for this sled. Even a 1.25 depending on what you want to do with it and if you will be studded or not.
NHTodd
I know 1" is stock. Was thinking of going bigger and definitely studding. Never done that. Any recommendations on tread patterns?
A couple of bucks
Go bigger and don't stud. There just is not shite for room under the 94-96 platforms.
I got an 1.5 to somewhat fit w/ 8 tooth drivers. But even then I still had to trim down to 1.25 where the tunnel coolers would make contact.
A 1" w/ stock 9 tooth drivers is all you are going to be able to stuff in there.
2.52” pitch drivers inches to Metric (rounded to nearest mm)
10 tooth 8.021” diameter 204 mm
9 tooth 7.219” diameter 183 mm
8 tooth 6.417” diameter 163 mm
https://totallyamaha.net/showthread.php/97649-96-XT6-to-144
Maim
Super Moderator
a 1" talon or ice ripper would be the ticket for that sled. i would lean towards the ice ripper if price is not a problem.
NHTodd
Alrighty well looks like popular opinion is the stock 1". So any where in particular is a good dealer for tracks. Like I said never done this before.
Maim
Super Moderator
quite a few of the site sponsors sell tracks.
A couple of bucks
Believe it or not, a 1" is an upgrade. Stockers were 3/4" I believe. 7/8ths at thee veeeery most.Alrighty well looks like popular opinion is the stock 1".
I'd probably look for a Hacksaw or it's prestudded version Ice Attack. Providing you have the coin that is.
NHTodd
Alrighty guys found a couple tracks from Composit that look good for good money one is 1.10" and the other is 1.25". Motstly gonna run this thing in my backyard which is a 5 acre field and any trails I can find. So which would be the better decision with no studs? Thanks for all the advice so far.
Todd
Todd
Maim
Super Moderator
1.1 max without driver change.
A couple of bucks
What ^Maim^ said!!! And at that 1.1 , NHTodd will stand for .... Not Happy Todd during the install.
When I said ..... STUFF in my previous post, I was not exaggerating.
