Headlight swap
Howden ,Manitoba,Canada
Is it possible to switch from a single bulb headlight from a 97 Sx 700 to a dual bulb headlight from a 2002 SRX 700. I would think that wattage is the problem,but can it be done.
Yes, I have done it, you need the headlight, also if you don’t want to change the stator, just use two 35watt bulbs, or a couple LED bulbs. You will also need the dual bulb gauge pod, and windshield
Only other consideration would be the wiring harness. I just soldered in an extra headlight plug to the original.
