hlmrx1
- Jan 6, 2005
Hi all, I'm looking at buying an SRX 700 bottom end with 11866 miles on the crank, the top end and seals were done in 2010, what should I look for, for wear? Do I need special tools to measure specs.? I'm mainly need the bottom case as I put a rod thru mine, but the seller is including the crank. What would be a reasonable price for a used bottom end? Thanks in advance for the responses.
pete_man26
What year bottom end are you looking for? I have a set of cases for a 98-99 I believe that I would sell. They are just sitting under my bench taking up space.
hlmrx1
- Jan 6, 2005
Thanks for the reply, I was looking for a 2000, and ended up buying a 2002 bottom end, I hope it will work for me.
'00-'02 all had the same bottom end so your golden.Viper cases are the same too if you wanted to build another bottom end for a spare.
