Vmax xtc 1997
Hi
any carb specialist!!!! I am trying to find a rebuilt kit for my carbs on vmax 1997 2 cylinder. But all my search are inconclusive when I put the above title in the search engine and the carbs that come back form my search does not look exactly like mine ( probably because they have 20 years?) . I am looking for all the gaskets, o-ring and specifically the seals that goes on each side of the tiny needle bearings on each carbs.
Can any one point me in the could direction or website or the exact rebuilt kit number that would have all needed?
Thank you.
Thank you.
Vincent
Well-known member
https://partstream.arinet.com/Mobil...QLaw9GDPSIkrbUbJ66v4-3G99MROGxulacOFDAM1.html
Just use the Yamaha parts finder near the top / right of the forum page.
Vmax xtc 1997
Hi Vincent, thank for the assistance. Yes I see the part numbers for the gaskets (however not available, but can probably find then somewhere else). But still dont see those seal on each side of the needle bearings where the throttle rod goes through.....
Not sure what you mean. No seals on the needle that I know of. Only the thin white plastic washers that sit at the top of the needles.
I would just replace the needle and seat assembly and the rubber o ring that goes around it.
Make sure ALL jets are clean, and your good to go.
Vmax xtc 1997
might be my french accent
that give me a hard time to properly explain my self. I will post a picture tonight.
