I want to still use stock exhaust and still look stock under hood. I have a stock 01 srx 700 with lightweight wrist pins and heelclicker clutch setup. I'm looking to run the best big bore kit and still use stock pipes and prefer stock carb setup. Who has info and opinion on best setup? Should I just do aggressive trail port? Opinions please.
hman
I have had a few. A Hauck,Simon's, CPR and I still have a 98SRX with a Maxximum Performance 780BB. The CPR780 was the strongest running for me. I had bought the Hauck 780 kit used and it was never the same as the CPR780. I havn't rode the Maxximum Performance 780 to much so I can't give you a good comparison to the others. warm them up good or they are hard on pistons! Mine all used Wiseco 73.00 mm pistons that I ended up having coated by Swain Tech.
madzx2
I have a Mr viper 780 and it hauls, even more after the 835 pipes and 38s
Sent from my SM-G950U using Tapatalk
