2003 Yamaha Vmax before and after
Augusta, Maine
Purchased this sled out of a guys backyard field as a project sled for my grandson to start out on. Here are some before and after pics. replaced, skis, seat, rear suspension, tail light, handle bars, plus gave her many baths and lots of scrubbing. Previous owner had a mice issue and removed electric start as the harness was chewed to crap! She is back and purrs like a redhead should! here are some pics !
38875457_2620258641333229_2764855222223241216_n(2).jpg38904019_2620258734666553_6097090978756165632_n.jpg
38985110_2620258697999890_6738189897942695936_n.jpg40628672_10156495943123830_6839322389055012864_n.jpg
3-4 years and well used before that! speedo says 4800 miles but the lower shaft key is broken off inside the shaft so not really sure.
That broken key is actually in an insert that's pressed into the drive shaft and can pull out and replaced. I read a thread about it on this site about a year ago.
that busted key usually points to bad jackshaft bearings
Bad bearing yes, but usually it’s the bearing behind the speedo drive.
If you take it apart, make sure the speedo drive actually turns, just found mine rusted solid.
Thanks guys, I already changed speedo bearing and noticed the key broken in the shaft. How can you get that out without destroying the shaft? square key right? wasn't aware that the insert section of square hole was removable from shaft?
Thanks Blue
That sounds like it would be very difficult while still in the sled. Needlenose? Drill it out.?
The real question is how many pulls did it take to get it started?
Even one season of storage and I'm looking at at least 75 pulls on my redhead triple. And even then it idles/runs like a like garbage until she gets a good rip.
Wow! My 700 redhead usually needs maybe a dozen or more pulls to start and within a few minutes will idle fairly well after 5 months of storage . I'm not saying that to brag, just the way my sled is.
1. Premix in a Dawn dish soap bottle.
2. Squirt into slush box.
3. Pull.
4. Repeat probably 3 or 4 times. MAXXXXXX
Note: be aware that excess fuel will be coming out of the slush box. Throw an old AFU cookie sheet underneath.
Had the ol girl out running in the yard yesterday, Pretty smoky start made for a good bug sprayer! Neighborhood blue smoke fume ! Burnt all the crud from inside exhaust! Now she runs pretty clean. should be a fun local trail sled!
