hello i am in a bit of a jam over my 1991 phazer 2 st it is running a 36 inch track on a skid off a different snowmobile that looks about the same size but has smoother suspension i bought it like this because the guy modded it and broke the drive shaft from track tension being to high i can not get her to fit back together after i took it apart to replace the driveshaft i put some no slip cogs on but they were actually a bit smaller then the original ones right now i am looking at trying to move the skid forward or get a bigger track please answer soon we finally have some snow up here.
Maim
Super Moderator
136" track right?
if your new drivers are smaller, odds are it will run a bit loose once you get the suspension in it. try removing the rear axle and wheels to get the skid in. i have a 340 polaris sprint in my garage with a phazer II rear suspension in it and that is how i have to put the skid in and out on it.
yes it is a 136 inch track i got the suspension in it but the track tension was so high that the drive shaft will not get into the proper location so i can bolt the chaincase and the spedometer bracket into the frame
A couple of bucks
Relocate skid. What brand skid is it off of?
Maim
Super Moderator
x2. the skid needs to go ahead at least 1". 2" would probably be too much.
