yamahaapex07
My uncle bought a 2001 SRX with a stock rear skid. I have a 2001 with an Expert X rear skid. His has adjustable Bender transfer rods. With that being said, the rear end doesn't sag more than an inch when standing and jumping on the rear bumper. We loosend both rear springs down til they only hold the spring tight but it's stiff as a board. I also have a 2001 SRX set up as an Improver and compared all parts of the 2 rear ends to make sure that they are both the same, they are. How do we get the suspension to sag properly???? We have experience with many different Yamaha snowmobiles, 2007 Apex, 2007 Attack, 2 600 V-Max, 2002 Yamaha Viper, and an 880 V-Max 4 Improver. We have had shocks revalved on different sleds, but I'm not sure this is the issue, usually the valving is an issue on big hits or higher speed..... Springs, revalving, etc....... any ideas are greatly appreciated!
Thanks all!!
Thanks all!!
JERSEYJOE
Why not do what I did. Get hold of an APEX suspension and put it in. The adapter brackets are only $75 and you can score an Apex skid for around $350.00. For that sum total you cant even get the stock SRX shocks revalved!!!!!
yamahaapex07
Mono shock?
shaggyzr2
Thanks all!!
Just have the shocks freshened up, that would help. I had mine done for around $30 per shock by Eric the shock guy. If you go with a different skid like an apex skid, then your rear will be long travel and the front will still be short making the sled sit higher in the back which you don't want, won't handle as good as it would with stock skid, you would need to also long travel the front of the sled.
https://www.facebook.com/EricTheShockGuy#!/EricTheShockGuy/info
JERSEYJOE
Once again you can long travel the front end and widen it. Well worth it. BETHEVIPER makes the adapter brackets to run the longer VIPER shocks on the SRX chassis. Add the wider control rods and you are done. the VIPER trailing arms are an added bonus but not 100% needed.
A couple of bucks
Does it have brackets that jack up the the backend?
Schocker65
What position is the FRA at? That has the biggest effect on compliance.
yamahaapex07
It doesn’t. We are wondering if the adjustable transfer rods are too long, we are going to try that first and have the shocks revalved.... thanks for the input everyone!
yamahaapex07
Do the brackets make it better or worse?
A couple of bucks
Way way waaaay worse. Shock geometry will be AFU.Do the brackets make it better or worse?
shaggyzr2
The 00-02 srx's had a shorter transfer rod, maybe someone put the longer rods in it?
i was just going to suggest that shaggyzr2. they might have blown the long travel rear shock or never put them in.
