Vmax xtc 1997
Hi,
lots of tension on the on the puller and not able to remove the magneto...... tried a bit of heat but not much as I am afraid to melt something (rubber/wires). Tried hitting gently on the puller to create some vibration, still jammed in place.
Left everything under tension and sprayed some WD40 in the small hole of the key way, added a bit more tension and vibration, and still laughing at me.
any advice????
thank you
Tension it up and give the puller centre bolt a good hit with a hammer...could take a couple tries.
If that doesn't work use an impact gun
shaggyzr2
heat it up, it will pop right off. don't hit it too hard with a hammer.
Vmax xtc 1997
Thank you guys,
Done!!!!! left everything under pressure for few hours and when I came back just a bit more tension and it came off.
