Comet clutching for srx 440
srx440b
Labrador, CANADA
Hi guys, looking for some help setting up a 78 srx for 660 foot drags. I've got a mildly ported set of cylinders, pipes,40mm carbs and 17/31 gearing. Looking for engagement of around 5500 - 6000 and peak of 9800 or so. Ive read a lot of the old post on setting up the srx for 660 but could never find a set up for the comet clutch. Any help would be greatly appreciated ^
Yamiegod316 I read a post from you from years ago for a setup on an srx with the 17 31 gears 40mm carbs ECT and you told the guy to go with the comet clutch setup you gave him. Could you share that with me. I've done a fair bit of clutching over the years just trying to get a good starting point so I don't have to spend a fortune buying weights and springs that I don't need. Also I just picked up a secondary clutch from a vmax600. Going to try and work that in. I think it will work better with the 108c and let me run the longer belt too get ful shift on the clutches. Any help at all would be greatly appreciated
