Throttle cable problem
ejcamaro
Life Member
Wonewoc, Wisconsin
Website
www.myspace.com
When I had my carb rack off to change jetting, I noticed that my throttle cable was loose where it adjusts on the rack. :o| Any way to set this correctly? My TORS is already disconnected (plus I no longer have the stock guages anyhow). Should I just start it up and check it at idle, maybe play with it till it seems right? I should just leave stuff alone cause whenever I try to make something better something else bad happens. I did find that I had the wrong jets though. ;)! ;):D
