mq32hunter
hey guys im new to the site and just getting back into sleds. i have a 97 vmax 600 twin and a 98 mountain max 700 triple. i live in eastern SD. i need to rejet and adjust the clutches on both these sleds for my elevation. they are jetted and clutched for a higher elevation. the previous owner gave me the jets i need. ive never worked on sleds. i have been around motorcycles my whole life so i have some wrenching exp on 2 strokes. that bein said. on the 700 do i have to pull the carbs off to get at the main jets or can i loosen the boots and turn the carbs? as far as the clutch i have no idea....same questions with the 600.... thanks in advance for any help
Yes, but you will need to pull the fuel lines.
Much easier to just get them out of the sled, go through them thouroughly.
Only takes me maybe 5 min max to get them out.
10mm wrench and a Phillips screwdriver.
Are you sure you know what jets are supposed to go back in?
And are the main jets the only changes you need?
1997 600 SX should have 151.3 mains, 45 pilot
1998 MM 700 should have 142.5 mains, 45 pilots (calls for a fatter main, but too rich in my opinion)
mq32hunter
Thanks guys. I bought them from a local guy. He gave me the jets to run around here (eastern sd), lower elevations. They both are jetted for higher elevations(western sd, black hills). I will dig into the carbs and see what I'm dealing g with
mq32hunter
To add to that the elevation here at home is 1400' and the elevation in the black hills is 3500'. Tha is again
Then stock jetting and clutching will be what you want to run.
mq32hunter
For the lower elevation I assume. But fatter for the hills?
Elevation has less air, so less fuel is required.
