Labrador-Ronin
I started started running around the Viper this season, anything under 20 kilometers an hour so make a sound like the tracks binding.
The boogies are good, slides are near mint, track tension is good, I changed the gear oil this year, the adjustment on the chain might be a little off but she should be good the chain probably is stretched I'm not sure I'm going to take the gears and chain up to the local dealership to see I've got the clutch cleaned up changed the sheave on it because that cracked but I'm still getting that noise I've noticed on the secondary clutch wiggles abit, 1/2 to 3/4 of an inch either direction before the track moves and the little triangle, clutch slides?? Are worn down a bit, and the sleeve that goes into the clutch has some deep marks, it has 3 shims and the main washer has a groove work into it, might turn it around.
I can't think of anything else anyone else have any ideas?
Sorry for the long winded paragraph.
Pictures in the link
http://imgur.com/a/9CuqlTV
staggs65
Everything in your pics is normal and wouldn't be the cause of your noise. The sliders for the helix could stand to be changed but not the likely source of your sound. A better description or a video of the noise would help.
Labrador-Ronin
I'll try to get a video of it I have the clutch off now, but it's like a Tuk Tuk Tuk until I get up to about 18 kilometers an hour and then smooths out I think I might be the change slipping on the gears I'm going to open that up tomorrow and see it's a dirty big expense I'll take some used ones if anyone had any haha
Bearing behind speedo drive, or lower chain case bearing?
Labrador-Ronin
I do think think the speedo bearing, I'll look, more pictures being added to the album shortly, here's a video link short but there's about an inch of take up before it tightens up to spin, sorry for my voice haha
https://youtu.be/-U1Qj7oJAYw
A couple of bucks
Take belt off and turn the track by hand. I'm wondering if the chain tensioner is AFU.
Labrador-Ronin
Truck is spinning okay the tensioners on the back end or okay slides are perfect the tensioner roller looks okay although the tensioner itself could been but I think it's alright I might take it up to dealership and see what they think it kind of sounds like the chains skipping, would I have to replace the gears and the chain, or get away with a new chain haha
front limiter strap break? could be the clips hitting on the rail tips. when was the speedo and jack shaft bearing last repacked?
bluewho
You are saying the secondary rocks back and forth if so yes the jackshaft bearing is shot.
Labrador-Ronin
It will be an inch of spinning the idler gear till theres take up.
I'm going to remove the jackshaft tomorrow, what size is the upper but on the gear?
And the jack shaft has never been out as far as I know, besides me taking it out to put the track back in
bluewho
Wrong shaft there.... its the one behind the secondary and the brake disk attached.The lower one is the john shaft. Chains do come loose never seen a gear wear down thow. You can adjust with the cover on just don't tighton more than finger tight.
Labrador-Ronin
Okay yeah the dealership said that the beard pics looked okay so it's the area that the speedometers in is it and how would I get to the exhaust muffler side of the shaft
You have to remove the exhaust and all the rest to get the chaincase and drive shaft out in order to replace driveshaft bearings, both sides.
Does the speedo work?
Labrador-Ronin
Yes it works perfectly, tach I'm not too sure of, I think it's the classis +/- 150 rpm lol.
What size is the nut on the top sprocket in the chaincase I can't find it in my toolbox I think I need to go buy a brand new one
Labrador-Ronin
I pretty much have it narrowed down, the bearings on the jack shaft, Im trying to get the nut off the top gear int eh chain case, anyone tell me what size it is HAHHAHA, I cannot seem to get a socket to fit.
Im goign to replace all the bearings on both sides the pulley side and the chaincase side, to be safe
Labrador-Ronin
I still am waiting on sockets, I bought a 36 MM, too big, anyone know the ACTUAL size?
Mac
My sled is apart. So i just checked. It a 29 mm.
Labrador-Ronin
Thank you, very much, now to find one lol
