83 yamaha 440 ss..oil cable pump setting ??
Yamadice
Wilmont Township
what is the proper setting for the oil pump injecter cable?...I keep thinking 21mm but I could be getting that mixed up with the setting for a vmax...Thanks
With cable installed and idle adjusted. Key off, carb in idle postion. Pull cable out of adjuster and adjust until there is 1 " gap between cable outer sheath and adjuster.
opsled
