Jimsrx
So I PICKED up this SRX over the summer as I learned more about it I find out it is 99 with a 01 motor. I say 01 motor Because the had a and jugs are 8dn-01. So my question is about the CDI box it is a 8dn-00 which I'm thinking is for a 99. So ia m wondering if there is any issues I should be aware off. Or if it is possible it's a 99 motor with 01 heads nd jugs?
Or even if any of this matters??
Its most likely a 99 bottom end that has the newer cylinders installed. Check the case serial number to see what year the bottom end is.
There are no issues using 98/99 cases with the 2000-2002 cylinders and heads.
The 98/99 CDI needs to be used with the 98/99 cases and stator.
Jimsrx
Ok I appreciate the info. I'm gonna look for numbers on the lower end..
