Just curious if anybody ever put a grease fitting on their speedo adapter? Took the track off to swap and was wondering if I should try it or just pack it full of grease before I put it back together. Thanks in advance. J B
I have seen it done before, but I am not sure how much it would really help with a sealed bearing? I have been running these sleds for years without one with no problems?
Simonsweden
Just put some grease in the speedo housing and you are good to go.
A couple of bucks
If you do , just simply remove the seal on that side.
