Hi, I put on a new camoplast 1 1/4 track on a viper, the track is clipped every window, I seem to a a vibration or growling at slow speeds, I have my front limiter straps let all the way out, would this cause more of a rumble of the hyfax and clips?, would adding small wheels by bend help. This is on a 121. Thanks
super1c
Super Moderator
That track will make a bit more noise then the stock track, Wheels wont help much, nature of the beast. Also check your belt, may have a flat spot, has stumped me more then once.
Vincent
Well-known member
I've noticed this as well with my Cobra. My straps are also on the looser side. Anyways in my case the clips strike the black plastic tips on the forward end of the rails. It causes a kinda growling noise and vibration under 20 mph. Past that it's good. I was paranoid about it for a few seasons t'ill I finally found the cause.
staggs65
Do you still have the front heat exchanger protectors? They will rub on most 1.25 tracks.
Nope,I took them out, thanks for the suggestionDo you still have the front heat exchanger protectors? They will rub on most 1.25 tracks.
