sleddineinar
I'm having a hard time getting my clutch center to center. I took the motor out to clean and repaint the belly pan. When putting everything back together, my C to C is supposed to be 10.47" but I can only get about 10.37 or so, is that close enough? I tried to turn the plate around, but it's not possible. So I'm wondering what I might have done wrong. I put everything back together following the manual and exploded parts views in the manual.
matty k
You can get a bit more adjustment by loosening off the chain case and moving it towards the back.
sleddineinar
Thank you! I hadn't thought of that.
