purchased an 87 exciter 570 from a friend recently. He didnt know too much about it, he just bought it with a trailer. he did tell me it was boggy at low throttle. It has the original mikuni butterfly carb
pulled the carb apart, cleaned and blew out every jet, nozzle, and entire carb body. cleaned the choke mechanism, and lubed the cable.
rebuilt the fuel pump with a new kit. replaced every fuel line from the tank pickup to the carb. I also replaced the pulse line from the engine to the pump. Installed new spark plugs, removed old gas, replaced with new premium.
engine has good compression, Im not sure of the numbers.
The engine will start first pull when cold every time. once I start riding around the yard for 5 minutes it wont idle without a little throttle. after that it wont start unless it sits for 30 minutes. Once i got it started again i tuned the throttle up to just before the clutch engages. The throttle was very responsive, I figured I had solved the problem. but after another 5 minutes around the yard it wouldn't idle without some throttle.
I might replace the choke cable next, I am up for any suggestions.
Thank you
Thank you
