P Herauf
Hi guys. I am working on a 2003 Sx Viper that I bought used.
This sled has had SLP Triple pipes installed on it. I seem to have a weak centre cylinder on idle. The pipe coming off the centre cylinder does not get even warm while idling. I have cleaned the carbs, and checked the reeds. I have swapped the plug, plug wire cap, and coil to another cylinder, but the problem stays with centre cylinder. While idling,I can pull the centre plug wire off, and there is hardly any drop in Rpm. Pull the wire off pro or mag and it drops way down. I have tried spraying fuel into the carb with no change. Pulled off pipe and fuel dumped out.
It does seem to clear up when you get it revved up on the stand.
Compression testing at 95 pto, 110 centre, 105 mag. These sound low to me, but it could be my old compression tester.
I plan to check the fuel pump and pulse line next, to see if the pump is loading up the centre cylinder via pulse line. I also plan to ohm test my stator using numbers I found on here in another post.
Any thoughts on where else to look? I was not able to find another post with issues similar to mine.
Thanks - Peter
Thanks - Peter
