s10mike
Does anybody know the size of the manifold bolts on an '01sxr700?
			s10mike
Check this out.
How to find Yamaha bolt sizes...
Every now and then someone asks what size a particular bolt is. Just thought it would be helpful to post this from another site. FYI, you can get the part# from most Yamaha dealer websites or here.
"How to get sizes of bolts from the part numbers...
The Yamaha microfiche shows the bolt size, you just have to know how to read it. Here is how it works...
The part number is broken down into 3 parts 99999-06012-00 is an example. The second part, which is 06012 tells you the size. That bolt is 6mm in diameter and 12mm in length. If the second part was 08024 the bolt would be 8mm in diameter and 24mm in length. The first part of the part number tell what type of part it is such as bolt, screw, washer etc. and last 2 digits generally determines the finish such as black, cad, etc".
It doesnt determine the pitch, but the size and length are there.
Good Info Mike, I knew bearings worked like that, but wasn't aware bolts did as well.
			jjmoneysauce
To add to this, the service manual usually has a page at the end which gives the thread pitches.
