Low voltage..
snowhite
Flin Flon,Manitoba
Hello members, going thru my '99 VT 600 and had her running and thought the headlight was dim. Checked voltage as service manual requires, black wire on headlight plug d yellow a rpm around or over 3,000 rpm. and only get around 9-10 volts. So does this mean the stator is going out? Or is there a lighting coil on it? Battery voltage was around 13 volts.
