benboat
Need some help. The power valve servo and gauge panel does not come on when the key is turned to on. In the past I could hear the servo cycling and the panel would turn on prior to cranking over. Not sure if related but the hand and thumb warmers are not functioning either.
servo will cycle when ke is turned on but gauge will not work until motor is running.
