What skis can I upgrade to. Prefer ones that would just bolt on
There are all kinds of after market skis that will just bolt on.
Maim
Super Moderator
x2. lots of newer yamaha skis around too.
heck there are a bunch of take off yamaha tuner skis from the apex, vectors, sr viper and sidewinder that guys probably are looking to get rid of as they went aftermarket for handling.
A couple of bucks
Get newer Yamaha take-offs for not a lot and put Bergstrom Triple points on them. I'm cheap like that.
Unless you get into the deep.
Simmons Gen I --- 6"
Simmons Gen II -- 10"
Simmons Gen III - 8"
Sled will be for trail riding only
Would Yamaha tuner III skis fit from an 2018 sidewinder
Maim
Super Moderator
yes they would but you will need to shim the rubber up with something as the saddles are taller on them than your stock skis.
Simonsweden
I have polaris gripper skis on my mm700 and im happy with them
A couple of bucks
If you can find some of these ...Poo Grippers in white, they look like they should be in porn. That good.I have polaris gripper skis on my mm700 and im happy with them
Jack99
Jimmy
Royal Distributing (in your GTA) sells lots of different skis & ski parts....
re: https://www.royaldistributing.com/snowmobile/
Hope this helps as well.
