Fuel pump ?
stealth82
Jefferson, WI
So over xmas i went and replaced all the hoses on the oil pump and fuel pump and it was last year when i took all of it apart to do a rebuild. Well i should've taken pictures cause now i dont know where the hoses on the fuel pump hook up to the carbs. Does anyone have any good pictures of these connections? Id appreciate it
The 3 closest go to carbs, the far one I believe is oil with check valve pointed towards the fuel pump, the top nipple pointed up is in from fuel. I can pull my airbox tomorrow and check.
So there are 5 nipples on the front and 1 on the back, back is fuel, standing on left side of the sled goes first 3 are carb, 4th one is pulse line to the case and the last or furthest away from left side is oil pump and check valve points toward the fuel pump. The check valve is there to stop fuel from gravity feeding into the oil pump.
