sledders
Around 3500 the engine goes into a oscillating mode like on a rev limiter. Believe it's carb problem, been there before and fixed, but 2 long to remember. Just happens on occasion. Nail it all ok. ??? Tks Jim
TORS maybe
staggs65
I'll give a X2 on the TORS. Throttle cable too tight or worn/dirty switches. Can bypass to see if that is the issue by unplugging the 2 bullet connectors going to carb rack and plugging the 2 on the wiring harness side into each other. If that makes it go away you know it's a TORS issue. I would fix it at that point as it's a safety device.
staggs65
TORS is to prevent this
https://youtu.be/yOobyiLMnY0
what staggs65 said-----
sledders
"TORS" Understand what you suggest. Slow idle 2000 With slack cabe. Around 3500 when this occurs the cable will be tight. Will conduct the test you have suggested. Thanks
