1998 V-max xtc 600 wheelie help?????
98vmax600
cape breton nova scotia
I am used to the polaris suspension where it is as simple as losen the limiter straps and take out the block in the rear.
well the straps are lose the rear spring doesn't seem too hard and the front one looks to be adjusted pretty hard. just can't seem to get her to lift her skis. my old polaris 500 xcsp would lift for 200 feet no problem .
is there any cheats or tricks to get this baby to lift her skis? she seems pretty fast.
Do you have adjustable transfer rods in the back on each side or solid rods with no adjusters?
Its the white plastic washers on the transfer rods that adjust the travel.
You could also loosen the limiter straps in the front some.
Just know that its set the way it is for a reason.
