1997 VT 500. The hose from the coolant bottle goes where?
norwegian
Well-known member
norway
I had the lower crankcase changed on the vt 500. Where does the hose from the coolant bottle go to? It is lose now and the sled is losing coolant. If I try to refill, the blue (which I fill in) will drain right above the heat exchangers.
