I have a V max 500 that I would like to jet and clutch for 6000-8000 Can anyone help me find the proper carb and clutch set ups? Thanks
I thought I was VIP Very sorry Please send me link Thank youAt that elevation you should gear down 18T/39T with 68L chain, Green Pink Green Primary Spring with the 8CR-00 Weights empty. 14.5 mm rollers. Red secondary spring at 3-6.
Jetting at that elevation is in the same Temp Range 0 deg F, MJ: #141.3, JN- 1.0
This is right out of the Spec Book. If you want to be a VIP for $15 I can send you a link to PDF.
Just sign up again thank you Sorry for the problems
