chazdo2
 The PTO side of my old 440 ring broke.  I think this is the first time its been apart.  Is the stock piston stamped STD and CN?  The cylinder looks perfect not a scratch nor does the fan side.  Can I get away with new stock pistons and rings wrist pin and wrist pin bearing along with new gaskets?  Its just a basic easy riding machine for us older guys.  Passed with flying colors a leak down test before I took it apart.
The PTO side of my old 440 ring broke.  I think this is the first time its been apart.  Is the stock piston stamped STD and CN?  The cylinder looks perfect not a scratch nor does the fan side.  Can I get away with new stock pistons and rings wrist pin and wrist pin bearing along with new gaskets?  Its just a basic easy riding machine for us older guys.  Passed with flying colors a leak down test before I took it apart.RON HYDRAULIC YAM
Pictures are decent but never as good as in your hand ,,, the LH pictured piston looks more like a foreign object came in the intake or dropped
the electrode off a spark plug some time in the past.
Or as you mentioned , broke the ring and dropped a piece in a port and drew it back in ,,, cant see any missing ring in picture..
you might want to hone first before dropping in the new parts and drive on
Ron
Ron
