S sledrunner New member Joined Dec 7, 2016 Messages 1 Location elk wa. Jan 13, 2019 #1 any tips ? The cent er bearng is also completely gone
super1c Super Moderator Joined Sep 15, 2003 Messages 5,492 Age 54 Location Freeland & Otsego lake, MI Jan 13, 2019 #2 Stuck on the bolts?
Maim Super Moderator Joined Mar 13, 2004 Messages 4,817 Age 50 Location sudbury on. canada Jan 14, 2019 #3 i would pull the snap rings (if it has them) and get the wheel out of the way. once it is out of the way you can use a puller on the bearing to remove it or cut them off if needed.
N NorthofSixty Member Joined Nov 22, 2011 Messages 356 Location Yellowknife, NWT Jan 14, 2019 #4 If you know someone with a hydraulic press just spray them down with deep creep and they should come off pretty easy.
A couple of bucks VIP Member Joined Jan 17, 2009 Messages 6,386 Age 59 Location Ogle County Illinois USA Jan 15, 2019 #5 A properly sized socket and a 3# mini maul. If not, the mating surface is too corroded and wouldn't hold a new bearing securely anyway. Last edited: Jan 15, 2019
