sxv2002
i have a viper with slp pipes.i have heavy hitter with their spring.
in the sec bender red/yellow on 30 deg it's a strong spring and stock helix.
the belt is slipping and the primary is really hot.i can't keep my hands on it.
what should i do? in the sec i put the silver same thing.
my center to center is right on. i have on a torque arm please help.
thanks!
thanks!
800
If your primary is that hot it means you don't have enough weight in it or the thing is over geared, then you're going to find out that you have to recalibrate your secondary. Most likely you're going to have to go with a lesser helix and a softer spring after you correct the primary situation.
sxv2002
thanks 800
