Hello, I purchased a Mountain Max 700 last year and it's in rough shape electronically - nothing works except the kill switch. Manual features like the brakes and choke work. Speedo, odo are dead. The key switch is busted up bad. It runs, and the engine seems to have tons of compression and the sled has buckets of power. I wanted to start with re-wiring the key switch, so I can control the warmer and start mode.
I want to start fixing it up but I can't find a wiring diagram for it. I was told it is a 2000 but I'm not sure. I'm new to Yamahas. I saw a partial wiring diagram on here, but I'm hoping for a complete one or at least a guide to the wire colors. Photos:
https://drive.google.com/open?id=1WqNkaZMdxL6C9Lh87VnbIcki1GZKumpi
https://drive.google.com/open?id=1ZR0rIAfmyLM3q-Ufc847o9IcKLHpC2WJ
https://drive.google.com/open?id=1B92CEyFiPWDQBQ3bIapiyrmmw_laPXNj
thank you in advance!
A couple of bucks
I am unable to help w/ a diagram. Judging from the lack of care that wasn't done, there are probably many more brittle wires that have not showed up ..... YET. A complete, out of sled harness rebuild should be in your future.
Yea, right now my priority is identifying the warmer and start circuits just so I can run it. I only have time to gradually fix it up right now. I've already got it running a lot smoother on the mechanical side.
FOUND it - manuals section of the yamaha website - posted here for anyone else looking for the wiring diagram.
https://www.yamahamotorsports.com/motorsports/owners-manuals
https://drive.google.com/open?id=1sVti1twgmtq5OZ1WwtuW_kbVz9ftZNE-
https://drive.google.com/open?id=1M8bHEDuU89SJF4AzGURiVzpNg8A-fSJ3
In case this shows up in google searches for others looking like I did.
A couple of bucks
Take another shot of the 3x exhaust. I cannot make them out on what little I saw of them. A triple triple redhead ..... bad @ss!!!
