not sure what it’s called but the rear skid shock has 3 different holes for the rear mount, does the position of this have any effect on ride height ?
MURDER YAMAHA
VIP Life Member
The lowest hole is position “C”
It is the stiffest, but won’t do a lot for ride height.
okay thanks, beings that i’m a bigger guy, would making it stiffer help with the ride height while i’m sitting on it? also can i change that position without changing anything else as far as suspension settings?
MURDER YAMAHA
VIP Life Member
Yes, it sure wouldn’t hurt.
Yes, you can change it without changing anything else.
okay thanks the owners manual says to have to have the dealer adjust it so i didn’t know if other things need adjusted in correlation with it mines in the middle so i’ll probably move it down to stiffen it up some
MURDER YAMAHA
VIP Life Member
Yep, just loosen and pull it down, retighten..
