Vincent
Well-known member
As the titles says. What is the difference? Seems the green is stronger the the red. Is this accurate and if so by how much? Example, Is a green spring set to 60 rap simular to a red at 80? Thanks.
red is softer then the green is, the silver is next step up from green. if you want to know the spring rates they are listed in the tech update manuals.
Vincent
Well-known member
Thank you. I had searched in the tech section before but somehow missed that tid bit of info.
For anyone else's information. Green spring is about 17% stronger then a red....
