Tether switch - which wire to use?
Jack99
North Ontario
Got a 1999 Yamaha Venture 600 triple and want to install a tether cord / emergency switch on it. Think of it as a secondary emergency kill switch. I removed its handle bar padding, traced its factory kill switch wiring and discovered it factory kill switch goes into a 3 pin plug. Upon testing with a short wired, I've discovered:
Pin 1 - black with white stripe (*)
Pin 2 - back with yellow stripe.
Pin 3 - brown wire.
If I connect pin 1 and pin 2, the engine cuts out.
If I connect pin 1 and pin 3, the engine cuts out.
My tether switch only has 2 wires - which is black and red wire.
With above in mind, what pins should my tether cord switch attach to? re: Pin 1 for sure. but, do I connect other wire to pin 2, pin 3 or both? Or does it really matter?
thanks.
Black/yellow is TORS wire. Not for ignition kill.
Connect black/white to black in harness kills ignition. That brown pin 3 would probably change back to black in the harness. I would use it as the second with. I just go into the harness and tap into black and black/white for my tether installs.
Also make sure your tether is a normally open switch.
opsled
Was a warm temp day today and I was able to use my multi-meter to "buzz check" the recommended factory wires on my sled. Outcome is shown below diagram.
FYI only - in case others read diagrams better then text words (for their future tether switch install).
Note: Since each make/model of sled might be different, always double check factory wiring and factory kill switch behavior via multi-meter - before tapping into its wiring.
Hope this helps future readers.
