Do I have the right speedo on my sled?
sdviper700
Dell Rapids sd
So I have a 04 viper mtn with DCS. Do I have the right speedo? I've seen some vipers with a speedo that has a dcs light. Reason I ask is I always have the warning light and temp light on constant but I've changed temp sensor and also have checked wiring for rub through. Here is pictures of it.
Sent from my SM-G960U using Tapatalk
Your speedo looks exactly like my 03 Mnt. Viper speedo. Blue high beam indicator and red warning indicator. Mine does not have DCS.
Someone with more knowledge of the changes between 03 and 04 will have to say if the 04's had a DCS indicator added to the speedo. I would think they'd want some type of indicator to let the rider know if the DCS was activating.
So did I that's why I'm asking... lol Never seen a viper with DCS in the head and the black guage.
This is a pic about 1 min after start up, lights never go away. I know it's not overheating as I've rode it like this for 4 years.
Found a used speedo from a member here and put it in, everything works as it should now so it turns out I did in fact have an 03 speedo on my 04 causing all sorts of odd lights on the speedo.
