I know this has been discussed before but have to bring it up again. I've been running Legend ZX2R semi-synthetic oil in my viper since day one, mainly because that's what was in it. Now in Canada Royal Distributing is no longer selling it nor can I find it anywhere in the area. What are you guys using for oil in your power valved machines?
SRXChris
Good old Amsoil Interceptor. I was told you get no build up or have to clean powervalves if you use it. That statement wasn't true, mine still require cleaning.
A couple of bucks
Legend = Sled Pro Distributing
been running ipone synthetic in dads sx venture since new and only when i run other oils as i am out do the power valves get nasty. found some royal purple to try this season as well.
Yamahakid01
AmsOil that’s all I use for my power valve they are always clean when I pull them
Jack99
I've been using Canadian Tire's Castor 2T sled oil since I was a kid. Used it since my grandfather and father used it.
Some time ago, my wife told me many times to throw my AFTER sledding clothes outside / on the winter chain link fence - to air out. Ya, that Castor 2T stuff stinks really bad. And, I didn't realize it. Ouch!
Since then, I've switched to Amsoil Full Synthetic Injection sled/boat oil (regular IO since my sled doesn't have power valves) and my clothes smells much less. And being full synthetic, I was also able to "lean" the injection volume a little bit as well (for less smoke and better looking plugs). Like a human body, better food (like full synthetic blend) mean less volume for same output results. Thus, switching to Amsoil is a win-win in the long run.
Note: For Power Valve engine, I'd use "Amsoil Interceptor" mix.
Guess you can teach an old dog (me) a new trick.... LOL!
